turbov6joe
Signal 1 J-12
- May 22, 2002
Ok, without confusing you all too much, I'll try and expalin this best I can. If I manually lock the TCC on a WOT pass, when the tranny shifts into 3rd, a violent shuddering takes place in the driveline??? You can feel it comming from under the car, so that's why I believe it's in the driveline. Now, if you make a WOT pass without locking the TCC, this problem doesn't exist??? Could it be possible that the converter clutch is slipping? I'm out of ideas at this point. Any opinions will be appreciated.
