I dont know if it had zinc additive. Doubtful. Dont remember the brand name. Its a black plastic bottle. To be honest I dont even know how many miles I had on the filter and oil...way too much is all I know. I did top off the oil a couple times with straight weight 30 dino oil from the gas station. Things were starting to look bad in the valve cover which is why I used it. It does work though. usually the oil is so thick that it cant completely drain out all the old stuff, and whats left over pollutes the next batch. This stuff made the oil so thin that it drained completely. 100 miles on this new oil and it still looks clean.
By the way, I do use synthetic. Always have. Usually use Valvoline? SYN oil. In some independant real world testing where they drain every 1000 miles and do an analysis, it came second behind Amsoil. Mobil 1 was like 3rd or 4th place. Ive used Royal Purple in the past and loved it. Now that its available at Pep Boys, I think thats what Ill go back to using. I used to go 8000-10000 miles on RP and it would drain out looking clean. Used to do 7500 rpm shifts with 600hp on a stock block in the cobra when it was still cold and never had anything bad happen. Its chock full of happy additives...great for flat tappets. I did get a blended synthetic this time. Its the new "Q" line of oils. I chose the high rpm one cause they didnt have the full synthetic in 20W-50. They didnt have the Q racing oils though. The Q racing oils (drag racing 17.5W-35..., oval track, etc) have alot of zinc. Avoid any oil that has that star symbol on it like the plague, because those oils are the ones that have been drastically reduced in zinc and other helpful additives. The Q oils dont have that symbol, and they do have the good additives, but the Q "racing" oils have alot more.
Given the lack of lobe oiling at idle, and the fact this engine flush was like water, I was just concerned that I could have started the lobe wearing process.
