OEM suspension height
eagleguy
With stock size P215/65R15 tires my suspension height measured from center of wheel well opening to the ground both front and rear is 25.75". Looking at other similar cars and after a little research I am thinking I am about 2" lower than stock. As the car has 27K and the height is the same front and rear I am wondering if it has been lowered a bit. Does anyone have a stock set up that can be measured like I did to see if I am right? Also if my assumption is correct and I want to raise the vehicle to the correct height does anyone have spring recommendations with part numbers or other ideas?
I just measured mine yesterday before I installed drop spindles and it measured 26 5/8 with a 245/50/16 tire. Now measures 25" after drop spindle install.
Dan
