Oil leak on front seal
mrose
does anyone know were i can find a speedy sleeve for the harmonic balancer i've repalced several seals and still slinging oil out from around the seal.
What cover are you using? GM? Aftermarket? IF Aftermarket it is probably the cover. Altho, I have never had oil leak there on any type of covers I used?
cover
Mine is a high volume cover, the seal installs from the front, do i have to have a special seal for it? i've been using the fel-pro #15200
also found the repair sleeve for it today national makes it #99193 that should take care of the balancer problem. I hope
Honestly, I have Never heard of a Sleeve for the Balancer??? Many builds.
I'm not sure on the part # for seal but I bet its the cover!! Not the seal??
Someone else may know the part number off hand? Guys???
Aftermarket covers are a Crapshoot IMO. I was lucky but many guys were Not!
