I have the HV pump (booster plate) and originally installed the 80psi spring and got 80+psi untill the engine would warm up.  I didn't like it so I pulled it and installed the 70psi spring.  I didn't lose prime and now it actually reads on the TTA gauge without pegging it.  Pretty simple to do.
BTW, it will not affect anything other than the max oil pressure.  It is for a check valve that bypasses oil when the pressure reaches whatever point (60psi, 70psi, 80psi).  It will not change your oil pressure in any way other than that.
