oil pressure
roderick
do turbo regals come with an oil pressure safty switch. and if so where would i hook my oil pressure guage to.
oil pressure switch
Yes, its all one unit next to the oil filter. Its a three prong sending unit that tells the ecm that you have pressure over 4 psi. If you dont it will cut off the fuel pump. Buy a "t" fitting and hook-up both. This way you can see what you are getting and the ecm will be "happy".
