Mar 4, 2010 #1 W Wicked WE4 Member Joined Oct 12, 2009 Messages 158 What is normal pressure for these engines? I am installing a mechanical gauge and was wondering what pressures I should be seeing.
Mar 4, 2010 #2 87granny Active Member Joined May 17, 2005 Messages 1,547 If it's an untouched engine the idle psi will scare you mine is like 12-15 psi at idle hot and that's with a new front cover and pump
Mar 4, 2010 #3 B bmackinnon Active Member Joined Feb 24, 2005 Messages 2,092 Rule of thumb is 10+ psi at hot idle and rising 10 psi per 1000 rpm... and yeah, many don't have the most confidence inspiring numbers...:wink:
Mar 4, 2010 #4 T TurboBuRick Moderator Staff member Joined Feb 18, 2006 Messages 10,083 bmackinnon said: Rule of thumb is 10+ psi at hot idle and rising 10 psi per 1000 rpm... and yeah, many don't have the most confidence inspiring numbers...:wink: Click to expand... That sounds about right. It's all about the rise.
Mar 4, 2010 #5 W Wicked WE4 Member Joined Oct 12, 2009 Messages 158 Got gauge hooked up. 20 psi at idle in neutral, 18 psi at idle in gear and increases 10 psi per 1000 rpm. So guess it is normal. Thanks guys.
Mar 5, 2010 #6 J Just a Six?? OK! Who Farted?? Joined Jul 4, 2003 Messages 3,574 If you do a 1/4 mile pass & its still the same or close to 15 then its good. Cold oil-hot oil etc can change a lot of the pressures you will see. Oil weight also makes a difference. Many use 10-40 or 20-50 to bring it up some.
Mar 7, 2010 #7 M maxcom Member Joined Jun 7, 2008 Messages 363 good info.....i ordered an electric oil pressure gauge (didn't want oil inside a 15k mile interior) ....will it measure OK or did i screw up?
Mar 7, 2010 #8 J Just a Six?? OK! Who Farted?? Joined Jul 4, 2003 Messages 3,574 maxcom said: good info.....i ordered an electric oil pressure gauge (didn't want oil inside a 15k mile interior) ....will it measure OK or did i screw up? Click to expand... I prefer mechanical but many use electric. I also dont use that tiny nylon hose but a steel braided peice that will never leak on me.
