oil pressure
gsbuick65
ok i got my motor finished putting together, tried to prime up the oil system I can't get any pressure, the machine shop didn't pack the oil pump so I put oil thru the sending unit hole, still no pressure, do I need to pull the pump apart and pack it?
Motors on a stand
the pump is right there in your face pop the cover on the and put engine assembly lube and reassemble. way to easy
