Oil Question...more or less
John84GN
Nice Monte...
Hey all...
I want to install a SS braided line to the turbo, and also an oil press. guage. My question(s) are:
1. Do I run both lines from where the turbo oil feed line is now, or is there anywhere else to tap into?
OR
2. Do I run a line to the turbo, and THEN tap off that connection for the guage from there?
Ya see, I want to install an electrical oil pressure guage, and I'm not just going to be able to tap a sending unit into a tee...am I?
Also, where to tap in on the engine for a water temp guage?
Thanks - John
O, I also forgot to ask, when I unscrew the turbo oil feed line from the engine, is oil gonna come pouring out, or will it just trickle...?
Oil Question
I put a tee fitting on the feed to the factory oil pressure sender for my gauge, as far as the braided line if it has an AN fitting you may need some kind of adapter for AN to pipe i belive.
Dale
