turbov6joe
Signal 1 J-12
- May 22, 2002
What does the electrical sensor that is located under the filter and part of the filter/cooler assembly do and how exactly does it function? I'm having a hard time getting my motor to fire when cold....it takes a bunch of cranking before it finally comes to life. Once running and the plugs clean up it runs great. This probem doesn't seem to happen when the motor is warm. My guess is that the sensor is a low oil pressure sensor and is malfunctioning not letting the motor fire when cold. I also noticed that this sensor is leaking, I wonder if this has anything to do with the firing problem???
