ok so im having problems with the "spray on" yellow light on the controller and the low alcohol red light under the spray on light the submersible pump works and the test button also works i took the line off and test it and its squirting water/alky but the spray on doesnt light up when the pump is on i got scared a while ago when i gave her a WOT down the street 15psi and still no alky wtf?? after i realized the pump was working it was just the lights on the controller any ideas i checked the fuse on top its good all connections look good grounds look good boost line good?
