SignUp Now!TRICKSIXPA said:My front tire sits about 1/2 inch from the front fender. I measured the distance from center cap and driver side was about inch wider. Now my car has been in a accident and has some frame damage. Goes down the track straight but I noticed the driver side front frame horn does stick out a bit more and there are a few more shims on my passangerside bumper support. I so know the body bushings on this car are shot so that could actually be an issue?
I just measured from frame to fender lip on both sides and there is a inch difference. So you think its just body bushings.
Look at the corners of the lower support bar. There are body mounts there. Thru bolts/nuts. Do some measuring to confirm it's off. If it is, you may be able to move it 1/2", to center it. [That mount does not sit in a hole, but has a sq hole inder it, in the frame, to allow for adjusting.]How do i fix that???
