One Way Valve Tm Kit
crazygn
10's here i come
Where does this one way valve go on the new v2 tm kits, do i just use the old y fitting or another one way valve. Just need to know what one to use , were it go's , and what way does it face i the line.
sorry with all the post just trying to get this thing done and tuned to post some new times
:D
The one way valve supplied with the kit should go on the drivers side port on the intake that runs all your vac accessories like cruise, and such. You can run a vac line from the intake port to the valve, then run a line from the valve to the vac block. The arrow on the one way valve should be pointed to the intake and not the vacuum block. That way, when you're under boost, the valve will close shut and the vac block will recieve no boost. Correct me if im wrong anyone. HTH :)
-Todders
I don't have the one that came with the kit because i bought just the intake from someone. I do have one here somewere that i can try tho.
Thanks for the help bud i'll try it right now since i called out of work to day.:D
Just fixing the pig on a nice day. Doing some welding on my pipes so they dont blow off. Trans is not shifting good , its a little low on fluid so i hope thats it.
As soon as i find out what the h--- is going on with this tps i can take it for a drive.
After about 1-2 years of having the car iam getting my scan tool this week.:D
Take care reds see ya at the track
