Need some help understanding the open loop idle idea and the troubles I am having.
At idle my car has 128 integrator & BLM. Is this set from the open loop? Is the computer adjusting during open loop? Regular cruise at 45 mph shows block learns about 140 - 150 saying lean. Full throttle O2's about 780 - 800.
My car at idle shows O2 volts around 800 telling me it's rich. The car smells rich and idles badly, vacuum about 14 and it lopes or surges. I turned the fuel pressure down from 45 to 43 yesterday and it seemed to help but it is bad again today. I did the IAC reset and found I only needed to turn the screw about 20 degrees to get 500 rpm. It almost seemed to idle better with the IAC unplugged! IAC counts are very very high, like 150 - 170.
Some specs:
Newly rebuilt engine. Comp 212 cam
K&N filter
Dual exhaust
stock turbo & injectors
vacuum brakes
I was thinking vacuum leak so I started eliminating items like the HVAC and cruise. No change. That wouldn't explain the 800 volt idle O2's
Other strange things:
I see 0 o2 volts occasionally
MAF at wide open throttle shows only about 235
I am probably rambling but it's late & I am getting frustrated!
Any ideas?
Some specs:
K&N filter
Dual exhaust
vacuum brakes
Any ideas?
