PAC Alcohol Kit Install Question
Raven
Here - watch THIS!
I know this is the lounge but I thought that maybe someone (that isn't browsing the Alcohol forum) might see my question and answer it. (There isn't anyone in the alky forum currently)
My question is this:
Ok, maybe I'm overlooking this but can anyone answer this question? In the install instructions for the PAC kit from Razor, it says to plug in the new 3 bar MAP and you're good to go - but what about the green wire included in the kit (along with the grey wire that comes from the Low Level)?
Do I splice that wire into the existing green wire in the harness that is plugged into the MAP?
What do I do with that green wire???? I know you need to send a signal to the controller telling you how much boost you're running but I can't find anything about splicing/cutting etc regarding the green wire at the MAP Sensor.
Help?
The green wire splices in to the existing green wire(middle wire).
I used a blue connector that folds over.
Thanks!
Thanks!
Exactly what I needed to know. Thanks a lot!
