matt921
- May 26, 2014
Ok so I am having the weirdest thing happen. I have always had a odd stumble if I stab the pedal in park or drive. It will kinda hesitate then clean out. So yesterday I swapped my fuel pressure regulator cause my old one was crushed and had close to 50 psi at idle. So after I did this swap and now its worse to the point that if I stab it and and hold it 1/2 throttle it will die. I'm at 43psi unplugged and 38 vacuum. But if I stab it wide and hold it it will fight through the spot but still falls on its face then clears. I had got my 87 ecm in the mail and figured well I'm in there. So I swapped it out did the iat and chip swap and a NOS AC DELCO MAF. It ran a million times better idle was smoother boosted faster. But still has the dead spot. I was thinking my tps so I unplugged it and bamn it was gone reved clean and strong. I did throw a check light but it ran great. SO I swapped my tps for a good one that I tested and was a nice clean sweep of voltage. .43-4.53 wide. But still did the same thing. Any one have any thoughts
