87 WE2
- Jun 28, 2002
Money orders & paypal accepted, + 3% for fee's.
Interior:
Center console shifter plate appliqué (just what is pictured) $45
G-body parts restored drivers side seat belt $70
G-body parts rear restored middle belt $25
Nice gray glove box, no key $30
Radio installation kit and wire harness adapter $30
Mount for cruise control box under dash $ make offer
Brake switches for brake pedal $8 each
Turn signal stalk, non cruise $5
Chrome door lock thing $ make offer
Door escution, small crack near pull strap $20
Boost knob bracket $ make offer
Center console cable grommet (2) available, $10 each
Seat belt trim piece $ make offer
Clarion head unit and cd changer $80
Trunk release button $20
Nice GN dash plaque $80
Dash pad, gauge surround, gray was painted blue. Needs repaint to be perfect again, $ make offer
B billar moundlings, pair $make offer
Windsheild trim, not perfect. Free pay shipping
Passengers side window Switch $10
Transmission:
Trans wiring clip $5
D5 converter $90 shipped
Tran’s cooler line mounts to cooler $5
Trans stock servo parts $ make offer
16 stock Trans pan bolts $10
Tran’s cooler line set $65
Suspension:
New MOOG tie rod adjusting sleeves $25
Frame mounts and bushings stock front sway bar $10 pair
Center link $10
Inner & outer tie rid assemblies with adjusting sleeves $25
2 good stock calipers $50
2 good stock brake rotors $50
Wiring”
10K mile tail light harness $100
10K mile cruise control harness $75
Exterior:
Original valve stem cap set $25
New GM door lock cover set black trim (3) $25
Locking fuel cap $10
Antenna nut and sleeve for top of fender. $10
Rubber isolator for fuel lines atop gas tank $10
19 used lug nuts, good for driver $ offer
Bumper spacers, gloss black powder coat $5 each
Engine
Original GM vacuum block rubber vacuum hose coup link’s $25
Oil cooler line clip $10
86/87 used original ECM $75
86/87 used original MAF $75
Set of factory original valve springs $25
Oil pump parts $ make offer
2k miles on new B&M Oil cooler $65
2k miles on new B&M Trans Cooler $40
Mini starter, complete with bolts $60
Low mileage GM timing set complete, no flaws $45
Good GM 02 sensors $25 each
87 style power steering cap $10
87 style power steering cap with chrome top $20
Washer bottle cap $5
Coolant overflow cap $5
Heavy duty IC hose turbo to IC $5
Water temp idiot light sender $10
Taylor spark plug wire clips $make offer
Factory oil cooler adapter $10
AC line plastic cover, larger one $5
EGR non ac-delco, working $10
T-stat housing $10
Stock stat new $5
Stainless T bolt style heavy duty house clamp 2” $5
MAF tube good for driver, $5
Horns $5
84/85 Oil dipstick tube, powder coated gloss black $20
Exhaust elbow $40
New 2 ¼” band clamp $5
Vacuum block nice used original $25
AC Delco EGR valve 2k miles $45
EGR plastic cover $10
EGR solenoid bracket with nut, poder coated gloss black $30
EGR solenoid 2k miles $75
Torque strap $15
GM 3 bar map, used for testing. Otherwise brand new $75
IC fan with bracket painted aluminum color and cleared $30
Factory power steering non pressure hose $15
Turbo crank shaft std/std, rear thrust surface worn. Will need over size thrust bearing rest of crank should polish out, may need cut .010 $125
Power steering pressure line $20
Coolant over flow bottle $10
AC dryer, Blue cap covering 134 fitting removed $40
Tools:
Jack, brand new good for track $25
Air hose 25ft $5
Trim clip tool set, new $6
Valve spring compressor for taking heads apart that are removed from the engine. Bought new, used once worked great. Comes with plastic case. $50 shipped.
I attatched a few pictures below.
Please go to the following link for all the other Pictures Parts for sale pictures by turbo231 - Photobucket
Interior:
Transmission:
Suspension:
Center link $10
Wiring”
Exterior:
Engine
T-stat housing $10
Stock stat new $5
Horns $5
Exhaust elbow $40
Torque strap $15
Tools:
Air hose 25ft $5
![P1010090.jpg](/proxy.php?image=http%3A%2F%2Fi229.photobucket.com%2Falbums%2Fee177%2Fturbo231%2FParts%2520for%2520sale%2FP1010090.jpg&hash=e06fb37be73d152b4d17653d53c8e281)
![P1010109.jpg](/proxy.php?image=http%3A%2F%2Fi229.photobucket.com%2Falbums%2Fee177%2Fturbo231%2FParts%2520for%2520sale%2FP1010109.jpg&hash=547d95c2eb52b89ebecc6c37432dd3b7)
![P1010110.jpg](/proxy.php?image=http%3A%2F%2Fi229.photobucket.com%2Falbums%2Fee177%2Fturbo231%2FParts%2520for%2520sale%2FP1010110.jpg&hash=b54b3518d9d656a7a434e2702e2ec1de)
![P1010115.jpg](/proxy.php?image=http%3A%2F%2Fi229.photobucket.com%2Falbums%2Fee177%2Fturbo231%2FParts%2520for%2520sale%2FP1010115.jpg&hash=fb3fc52f9447b15bb95ac762089f8f74)
![P1010116.jpg](/proxy.php?image=http%3A%2F%2Fi229.photobucket.com%2Falbums%2Fee177%2Fturbo231%2FParts%2520for%2520sale%2FP1010116.jpg&hash=2621538adc36805aa33566272a1e806c)
![P1010117.jpg](/proxy.php?image=http%3A%2F%2Fi229.photobucket.com%2Falbums%2Fee177%2Fturbo231%2FParts%2520for%2520sale%2FP1010117.jpg&hash=489b0492ea9a6d919a90b4ad90c31a8c)
![P1010118.jpg](/proxy.php?image=http%3A%2F%2Fi229.photobucket.com%2Falbums%2Fee177%2Fturbo231%2FParts%2520for%2520sale%2FP1010118.jpg&hash=76086dee0b45295bce58d837406898d9)
![P1010057.jpg](/proxy.php?image=http%3A%2F%2Fi229.photobucket.com%2Falbums%2Fee177%2Fturbo231%2FParts%2520for%2520sale%2FP1010057.jpg&hash=713631af37991ff9af1b095bf1a0aa30)
![P1010137.jpg](/proxy.php?image=http%3A%2F%2Fi229.photobucket.com%2Falbums%2Fee177%2Fturbo231%2FParts%2520for%2520sale%2FP1010137.jpg&hash=a4e951322b2b659ddba7c75f131a8536)
![P1010133.jpg](/proxy.php?image=http%3A%2F%2Fi229.photobucket.com%2Falbums%2Fee177%2Fturbo231%2FParts%2520for%2520sale%2FP1010133.jpg&hash=d9eac773d4d0e431ebc7902d981a9c86)
