PCVless
Blwn87
"You have a vacuum leak?"
Alright I think I solved the problem with my consumption of oil. THANKS TO THIS BOARD!! Running PCVless seems to be working but now I have the question on how people are running PCVless. My pops rigged up a red neck blocker for the vacuum manifold hose and the PCV hose, spark plugs. But that can only work for so long. So how are you running your PCVless setups on the street?
Since now that there is going to be more crankcase pressure we are thinking about putting some $$ into the vacuum pumps. Car runs and idles a lot differently without the PCV and think its because of crankcase pressure. Is there anyone running a vacumm pump?
nah just run it without one for a while an then take off your intake an look at the "milkshake" under it:rolleyes:
PCV?
All the 90's F-bodies and also the Caddys use a elec vac pump w/ no pcv system. Look how they are set up and do something like that...
Without it, look for what Grumpy tells you....:D :cool:
You don't get the milkshake without the intake bathtub. I took my PVC off and plugged it off. Right now, I just have two breathers. I've got an LS1 smog pump (blower, is not a vacuum pump) that I'm going to suck with and drop that air into a breather tank.
My intake was clean on the bottom when I took it apart last year. And before you complain about the heat soak from hot oil, the intake is already an air gap design.
inside my motor looks great after many hard miles with no pvc and breathers in both valve covers
