Please Help
nash421
Put on rjc power plate and put back together now car starts and turns right off. Sprayed brake clean in intake plenum to clean while apart. kicks over and cuts right off. Any ideas?. I didn't mess with iac or tps
yes, everything is plugged back in. the shitty part of it all is the car already had a rjc plate and was running amazing. Im a moron
Check all hoses, re-connect any elec stuff moved, dis-connect battery / ecm , check fuel pump relay & fuse for ign, etc...............
double check the coilpack install the module is grounded thru the bracket I always ran an extra ground to the firewall off the base of the module where it bolts to the bracket.
