Hey guys need some info on what spark plugs I need to run with my cars new setup? My combo is a built motor with champion aluminum heads,218-218 flat tapped cam,70 GTQ turbo.Whats a good NGK plug or ? Thanks for any info.
I use NGK R5671A-8's mostly. The last number is the heat range. With NGK's, the lower the number, the hotter. My car likes the 8's. May want to start with the 9' and move your way hotter by reading the electrode strap.
Advanced Auto's part number for the 8's is 4554. They are $1.99/each at the store I go to.
30+ It's a stock stroke, .020" over bore that makes power just north of 6500 rpms. Other than the high boost, the tune is pretty conservative, low timing and afr's in the 10's. I like it that way because it doesn't brake.
