I used Autolite 104 in my GN1 heads with great success. However, when I got my new GN!R heads the plug hole is 12 mm instead of 14 mm. The reach is .75 and it requires a gasket type plug, not a tapered plug like the Autolite 104 for the GN1 head.
I searched for a rather cold resistor type plug that would meet the dims and could not find one other than an $86/each NGK exotic plug.
I found an Autolite AR 4132 plug that meets the physical dims and is a rather cold plug, but it is a non-resistor type.
I use XFI and a MSD 10 Plus box with a distributor and Magnecor wires.
Does anyone think my electronics will be plagued with EMI using the non-resistor plugs?
