Poor idle, occasionally lumpy
BJM
Senior Member
The car drives seemingly fine but when it idles it sometimes misses a bit and then recovers. I hear snapping noises near the coil at idle, does that mean anything?
I tried putting a short 1.5" clear tube between the coil and the plug wire one by one on each of the front coil terminals. The middle coil sparks seemed much stronger than the outer two coils. Even when its sparking it doesn't seem to do it visibly on every firing it intermittently shows no spark even though the car is still idling.
Not sure what to try next.
