While my car has been down I have been doing some thinking about my Low Performance issue.
1. Low Timing? Could it be possible for the relucter ring to move on the balancer throwing my timing out of wack? Can I put a timing light on it? If so what do I look for?
2. Cam Sensor? Could I have installed my cam sensor wrong? Or can you even mess that up.
3. Chip? I also have reasons to believe my chip is not right. It was burned for my application but it does not cycle the O2s like it should. I did this with 3 O2 sensors and then swapped chips with "silentbutdeadlys' TT chip and it started cycling the O2s.
4. I know there is something holding back it's potential and it would be nice to find it?
Any help would be appreciated.
Thanks,
Jason
Thanks,
Jason
