We now have a better solution than a reproduction unit. If you do not get my free wekly inenr circle email me
denniskirban@yahoo.com
to get al the info as it is not yet on our website.
I found a guy who been rebuilding them for ten plus years uses a steel plastic sleeve cable rather than the plastic one like GM used..problem is the plastic gets brittle and breaks.
we also sell a booklet that explains in great detail how to remove your antenna as it has to come out from the bottom of your fender. Takes special care to do it so you do not kink your fender.....
we sell a reproduciton but currently out of them...we do sell a replacememt cable which is one optiion better option is we canget yours rebuilt for I believe $99.95 simply call my office and we give you the address to ship it to. It will be better than new.
I currentl yhave this source building units for me they would run I think $149.95 again better than the repros as the cable is steel not plastic.
we also sel the reproduction with the special bracket....some companies sell the same repro with no bracket no idea how they recommend you secure it to your car...so options exist...
power antenna failures is probably second to powermaster failures...3rd would probably be the cassette failing which probably don;t bother many owners.....
My office has the info.
Like I said the weak part of any of these antennas is the plastic cable inside....kinda like filler panels they get brittle after awhile...
