BBcallaway
- Jun 21, 2007
Has anyone removed a power antenna from a GNX? Are there any tips you can share. I know there are 4 -10mm bolts plus the antenna bolt inside the passenger door . There are 3-10mm bolts in the wheel well . I have removed the access panel in the wheelwell also a long with the flare trim screws, but I can only pull the fender out maybe 1/2". any tips will help.
