Power injection light
Dhos1
Self-tuning wanna-be
Just started my car and the power injection light comes on and stays illuminated...wtf. i know what its for, but never had it before..now the crap wont go out. Wtf man
Odd, because as built there's no bulb in that socket in the turbo regale.
When i installed my alkycontrol kit a few years ago. I hooked up the dash power injection light to use for the activation light.
Yeah, i got that part...but i cant explain why it came on
Okay...looked at my scanmaster and I have a code 34 for a bad MAF. I reclocked it a few days ago....i will reclock it and see what happens
Reclocked it and it's still fudged up. I bet when i cleaned the pipes. I remember setting the filter up right. I bet that KN FIlter leaked shit all on the sensor
Cleaned but its still the same.
Scanmaster readings are as follows:
Af. 24
L8 48
Bat 13.4
Int 128
BL 115
Mph 0
Clt 165
Ats 76
Rpm 875
Tps .52
IAC 0
CC. 65
PU 2.0
SP. 27.2
MAL 34
MAP 0
BST 0
E 32
I got the 34 mal...bad MAF
But the power injection light is still on...i have no idea why. And when i put it in reverse...it seems to starve it for fuel and my PLX wideband screams lean condition, it sputters and dies.
I have no clue here gents. Should IAC be higher? How about cc's
I did some comparison and my last readings for IAC was 33. It idles fine
Just adjusted the TPS down to .42....iacs jumped to 25.....i think im good there now. It still sputters and cuts off in 1st and reverse. It idles fine. I immediately go into a lean condition and done. Cc's are at 5 also.
Well she idles better. Ill check my translator switches and who knows what else.....jesus these things are finiky as hell. It broke just sitting there on jacks lol
So your check engine light is somehow switched into the spot where power injection socket was.
No i did not. Im guessing if i start it again i will have to reset the parameters since i did not reset it...thanks.
Man, someone give me another suggestion before I burn this damn car. I swapped the MAF and it still pulls a MAL 34..WTF. Still has the same lean condition because the PLX gauge goes pegged out to the right..LEAN and I start knocking. Put in in gear and the SOB cuts out...
