I had the passanger window down and back up earlier today without any troubles. Now it is stuck halfway up and it looks like its going to rain so i have the cover on right now.
Both the drivers side switch and the passanger side switch wont move it.
The drivers side window goes up and down fine.
I did some searching on the forums, but did not find a senario exactly like mine.
I did try wiggling the drivers side switch and passanger switch, to see if it was sending the "off" signal but had no luck.
Where should i start?
Based off of what i have been reading a lot of power window problems are caused by the switches rather than the motor. (correct me if im wrong)
I do have motors off of an '85 Oldsmobile Cutlass as well as the switches. Would these parts be interchangable?
Thanks in advance
-Mike
Thanks in advance
-Mike
