Power Seat and Power Mirror problems
LosOjos
My power seat joystick only works in 2 directions (both diagonal), and the motor acts VERY tired. My power mirrors only jump in large increments, no fine movement. Thay also will start to tilt down, over a few days, so I have to re-adjust them. Any advice would be greatly appriciated.
The door has a clip that takes the weight off of the cable going into the remote mirror. If during a paint job, the cable was not routed back through the retaining clip, the weight of the cable could cause the mirror to come out of adjustment when you hit bumps. You need to pull the upper door panel and make sure that the cable is supported by the retaining clip located a few inches below the mirror mounting point.
Great info, Turbo Brian! I'll check the cable this weekend when I have the panel off to align my windows. Thanks.
