The big hose that connects to my power steering reservoir is kinked. Looking to replace it but I only found what looks like gbody sells it....does anyone else sell it? I checked Kirbans but didn't see it....
I had to order mine from autozone...18 bucks, then I cut to fit....I couldn't find it as bulk hose but if you can it's basically a 5/8 power steering hose.
It only comes as a straight hose. Cut it to 17 1/2" it should be fine. If you cut it too long it will cink up. I know Gates sells PS hose but it comes with like 36".
Yea mine came as a 3 foot straight hose and I cut it down...its fine. Just make sure it doesn't kink up or hit the steering shaft. The constant friction from the steering shaft tore mine up.
Interesting. I would have thought since the hose comes off of the reservoir and then connects straight to the power steering pump, that it would have had a 90 degree bend in the rubber hose, from the factory.
