Are the powerlogger and the SD chip compatible with my "stock" hotair buick. If not what mods are required. Also can I buy this chip and tune it myself or do I have to send it to him everytime I want to make a change.
No- These are not compatable. Look on the Turbotweak website for the various options. The first thing is to get an 87 ECM and start doing your homework. You basically need a new chip any time you upgrade injectors, turbo, fuel etc. Brad
No. You need an 86/87 chip. The calpak chip is the same. Then you have to either install a MAT sensor or order a TT chip witch is burned to ignore this sensor. The 84/85 MAF will work but run a little rich. Brad
