I am diagnosing my brake system and before I just order an accumulator I want to be sure that is what I need. After pumping brake pedal 12 times ign off, turn key on and pump runs for 15 secs and brake lite goes off after 13 secs (another time was 13 sec for pump and brake lite goes off after 10).
No pump starts within 2 min with ign on and no pedal. Each time I push the pedal the pump cycles 3-4 secs and the lite comes on and then goes off.
I don't have a pressure gage to check the accumulator pressures so is there anything definitive in my test results here to tell me exactly what it may be?
Also the travel seems to be excessive from what I am use to. Thanks
paul
paul
