meanchicken
gallo vicioso
- Oct 6, 2007
I just finished overhauling my rear drums and front disks. I used ll NAPA stock replacement parts and used Dot 4 synthetic fluid. I bled the system thoroughly after pumpin it down and also syphoned off the old fluid from the bowls and replaced it. Peddle is firm after bleeding and the car stops great.
...but...
During my test drive, when slowing down or when sitting at a stop, I could feel the peddle vibrate slightly every once in awhile. While sitting at a stop with my foot on the peddle when the peddle would vibrate, I could hear the Powermaster motor run for a few seconds. The frequency of the power master motor turning on and off was as often as every 5 seconds or so (5 on....5 off for several cycles). Most often it would cycle once for a few seconds every minute or so while sitting with my foot on the peddle. The peddle only vibrates for 1-2 seconds when the power master motor first turns on.
Is this normal or do I have a new problem?
Thanks!
Tim
...but...
Thanks!
Tim
