Ok i read some troublshooting guides on the gnttype website. I have no visible leaks and my p/s level went down and i think i may have sucked in some air. with key on i press brake pedal and i get brake light for a split second. If i pump my pedal with key off the more i pump it the more fluid returns to resevoir to the point it almost overflows. Then with key on the pump will run for about 17 seconds. If i just pump it down with 10 pumps of the pedal the motor runs for 8 seconds. Im thinking first off i should bleed the system since the motor side may have went empty but where did the fluid go. Is there an internal leak somewhere. This is the first time messing with this in the 12 years i owned the car. Thanks for your help.
