626gn
- Feb 15, 2009
Is it normal for the Brake Switch Connector and Motor Connector to have a little bit of brake fluid in them or are they supposed to be bone dry? Fluid isn’t leaking out of the connectors, its just a little wet on the inside. No fuses were blown and brake light is not on.
I did lose power assist a few days ago (light came on that time) and the motor stopped running for a little while. I unplugged the brake switch and motor connector and noticed a very small amount of brake fluid in them. I checked it with my meter. Everything checked out ok so I wiped the connections, plugged them back in and the motor started working again.
Now, when I turn the ignition on, after depressurizing the system, the Powermaster makes clicking sounds for a few seconds after it cycles the fluid in the bowl back into the Accumulator. The motor doesn’t continue to run, it just clicks a few times then stops. Brake light does not come on at any time during this process. Brake fluid is changed every 6 months to a year with the engine oil.
I’m thinking I definitely need a new Accumulator to fix the clicking problem but what about the fluid in the connectors? Am I possibly dealing with a separate problem with the Motor and/or Brake Switch?
Many will say to convert to Vacuum or Hydroboost and be done with it but I’d like to continue with the Powermaster unit if all I need is a new Accumulator. If the motor is on its way out then I’d consider converting.
