John Morgan
- Nov 15, 2002
Hi Everyone,
I am new to this board but have been looking at it for a while and the TurboBuick web site come very highly recommended. I have a Mustang but have seen that everyone here gives good advice no mater what kind of car you are drivng.
My problem is that I have just finished installing a Gen 7 system ( with the WBO2 and currently running it in bank to bank mode) and the MAP sensor is giving me trouble. I am using the 1-bar MAP with my supercharger not hooked up for now while I break the car in and learn the Gen 7. At idle my MAP sensor is reading 3" of vacuum while my boost gauge is showing 10" of vacuum. I checked for vacuum leaks and found none.
I have tried replacing the MAP with another new 1-bar MAP and the same 3" numbers came up while the boost gauge still showed 10" so I dont think the problem is a bad MAP sensor. I tried using a different vacuum source, and the line to the MAP is a dedicated line off of the intake with nothing else teed into it, but that made no difference either. I get no error codes from the Gen 7 so everything appears to be working ok with the ECM.
Does anyone think I could be getting feedback from another system on the car that may be interfering with my MAP readings? The car is running ok but I cant really start trying to tune it until I get an accurate MAP reading. Any help or suggestions would be very much appreciated.
Thanks, John
Thanks, John
