T
tbronk
Guest
I need a little help with my 85 hot air. I overhauled the motor about 15 months ago using a camshaft and lifters from Poston (gn110t & hi rev lifters). About 6 months ago I noticed a tapping noise on cold start from the right bank after the car sat for a few days. The noise would persist for about a minute than go away. I pulled the heads last week to replace 3 teflon valve seals (from Poston new @ overhaul) which had come apart. When I restarted after completing, all was well, untill the car came up to operating temp. Now I have a lifter tappping after the car warms up. Any one have similar problem? It looks like "I'll be going back in" to replace lifters-Who's lifters are you guy's using, type, manufacturer?
One other note, I'm just started running direct scan, my Knock retard is running about 8 degrees at wot, o2's 850s, 15psi boost 44 psi fp could a bad lifter(s) contribute to this?
