Procharger IC on TTA
89mulletbird
Since I can't find a nice front mount anywhere for my TTA, what about using the Procharger intercooler that mounts horizontally behind the front bumper on a TTA? I had one on my supercharged GTA, but do you think it outperforms a dutt-neck TTA IC? The plumbing is definitely much longer on the front mount, dunno if that has much negative effect.
I have a nice IC I was going to use for my car until I bought a TTA specific stretch IC off Jarred. It is a big front mount and will need a little fabbing to work. I call it the "Snowman":D
You can see it in my sig pic hanging on the wall.
If you can't find a front mount I would get the Jim Dunn slic it is a great piece and will get you low tens for sure.
I contacted Jimm Dunn and got a quote. I'm concerned about how low it may sit? I cant even get a low profile floor jack underneath my stock IC shroud :(
There is no good spot on the passenger side, my exhaust is in the way of the SFC jacking point so I jack up the engine crossmember.
You wont be able to get a jack under the Jim Dunn IC then. I cant even get my oil drain container far enough under the car without it hitting the IC scoop and thats with 28'' tall tires.
