I might have what you need.....
It's a car that came from TN that was lightened up to go fast. It is basically just a rolling chassis right now, and has a cage in it. The whole front end is fiberglass (needs re-mounted) and was designed to tilt forward, or totally come off, or just take the hood off. Makes it nice when you need to work on the motor & stuff, could just sit on the tire & all kinds of room. Trunk lid is fiberglass too. All could easily be swapped for steel parts if wanted to make it more like a stocker.
There is no motor or trans in it right now. It has a 7.5 rear in it to get it to roll, but not good for racing. I got it to test fit parts & prototype from, and don't need it anymore. I will add in a suspension kit of ours for 20% off for whoever buys to help out it if interested. Also 20% off motor/trans mts too if you need them & buy the car. Also have a line on a good 8.5 rear reasonable, and can get new Moser stuff too if need a 9" or 12 bolt. Might be able to help with motor & trans too if looking for it all, lot's of possibilities & will do what I can to help out.
Needs paint & cleaned up, but decent piece to start with. Has some rust but seems to be the worst on bottoms of doors. Can help with new doors if you would rather just change them vs fixing the rust. Trunk bottom seems OK & bottoms of floorpan has a few spots but not totally wasted. Rather see someone get it & fix it up, vs sitting around here doing nothing.
Please send me an EMAIL and I will send you more pictures & info. It's not pretty right now, but has lot's of potential & will go FAST for someone on a budget! Plus I'm in the mood to sell it
Had $1900 on it, lowered it to $1500, don't have time to list it & take calls & show it, so make me an offer! Let me know, cash talks!!! Located in OH, basically between Akron & Youngstown.
