pt-54
My signature says a bit I guess. If I stayed into the throttle, would have been a 11.3x at 120mph or so. Lotsa fun......
10.96 @ 122 with my Factory Stock Motor, Front Mount and 3200 Stall Convertor, 10.58 @126 with Ported Irons and a 218/212 Cam........
at what psi were you runing
an what were your 60ft times
thanks for reply
what is a bigger turbo, the PT54 or a PT60. I am thinking of getting a PT60 any input on this turbo?
is your car more of a street car if so how is spool up on this turbo
My car is mostly a street car with some track time. It spools up quite quick, thank goodness for drag radials........
thanks for reply
Ahh...not sure with the 10.96, 30psi boost gauge was pegged the whole pass, 26psi or so with the 10.58.....60 fts were low 1.50s and high 1.40s.....
I'm not as fast as the fast guys here, but I haven't ran the 54 on race gas yet. At 24 lbs of boost and 23* timing on pump and alky I run right at 12.0 @ 115 with a weak 1.9+ 60' time. I'm running nittos and I either smoke them off the line or about 30' out.
On the dyno with very little tuning, it put down 405 hp and 545 tq in street trim.
how the this turbo spool up on the street for you an what stall are you runing
I'm running an .85 housing which tends to spool slower, but I run a 3500 art carr non lock-up converter, so it spools almost instant.
