If anyone needs the correct size fittings i have been on a mission the past couple days and figured out the exact fittings my combo is a 6765 Precision ball bearing "older version" i also have a Turbo saver,
Oil Feed Fitting is a -4 male to 7/16" -24 male i used a NOS jet to restrict the oil .035 jet i had to also use a reducer from -6 to a -4 because of the turbo saver the turbo saver comes -6 and to plumb to the oil feed i needed a reducer..
Water Fittings are 14mm x 1.5 then i used a -4 reducer with push lok end to route the water lines to heater lines. hope this helps, the only reason i post this is because not much info on internet about this, and when i called precision they gave me incorrect info... they were giving thread sizes for newer billet models, and other sizes, then i called back and explained in detail and then they wanted to sell me there fittings for triple the $$, also full throttle has some water fittings they sell each for about + $20 EACH water fitting..i bought both Water fittings for under $16 some of you guys will say i should have ordered it from precision or w.e but i got the same results as what they are selling on a budget. hope this helps, i bought some spare's for future use etc if anyone has any questions feel free to pm me, thanks..
