pump lubrication
I have Razors Alky kit and i think i remember reading about just spaying a little WD-40 or something better if there in the tank alky tank to lubricate the pump?
Add nothing or else :eek:
Run it plain.. no additives..plez
You dont.
You have this type of pump confused with like an inline EFI type pump that has steel rollers... The alcohol doesnt touch any metal surfaces. The first gen SMC kits required lubrication for the pump.
The motor has bearings.. but those dont touch alcohol..
Adding a lubricant may attack seals/rubbers in the pump. Now you know why I said better not :eek:
HTH
ok..you the man......i have enjoyed the kit since the day i was able to go over 16lbs of boost on pump gas...and the directions an how to hook everything up were percise....everything worked the first time with no problems...installed and tuned the car with in half a day....thank you.. 87 White T
