Purple wire H7 wire
sawmillman
Make logs into lumber
Where does the purple wire go on the C100 H7 block,does it go to the ecm or directly to the transmission?This is on the engine harness
Ooops I meant h6 the tcc lockup.I have found it goes to the ecm/lock up,does it need a signal from the vss for lock up or just 12v?
