cottonpicker14
- Feb 17, 2005
My O2 readings are generally in the high 800's at WOT. My setup is
Alky
TT chip
FP 43 line off
30lb injectors
Other usual mods as well, Walpro, Scanmaster, etc
MY BLM is at 134 at idle hot
Question is, how would you go about leaning out and getting the O2 reading to come down. Should I decrease the fp or reduce the amount of Alky by turning down the dial ? It is currently set at 6 on the dial, 22lbs of boost and I get a reading of .05 on the knock on the shift from 3rd to 4th.
Any help would be appreciated.
Alky
TT chip
FP 43 line off
30lb injectors
