The valve positions on GN-1 heads are slightly different than the stock 8445 head. The rocker arms should align over the stems perfectly, if they don't, it is possible that the rockers were ment to be on the stock head. T&D will sell the correct spacers and shafts to convert them if you choose this route instead of replacing the entire set. HTH, John
