question
87lightweight
i am running a te62, using a non progressive alky kit can i get away with using stock intercooler? i plan on running 17-18 pounds of boost.
Im using a stock intercooler with a 6776. You may get a little more from an aftermarket IC, but the stock one will work just fine. Alky with the IC will help cool the charge. You could run more than 18 lbs if you want. I run @22-23 lbs through my stock IC
