Racetronix's Hotwire
gn86randy
No can......can
Appears my connectors on my car are ARSH backwards I have a female connector coming from the Tank side and a Male connector at the rear bumper, and I suspect that this is backwards since I have not one but two Hotwire kits with the large heavy guage RED wire on the female connector which should go to the pump.....am I way off on this or am I correct about my wiring is AZZ Backwards........I really don't wanna have to drop the dam Tank again this will be third time in less than 2 months.............."DAM IT JIM":confused:
Was this problem solved?
I know the GN and TTA hot wire kits are different is it possible you got a TTA kit? The Pump connector on F- body is male and the body connector is female. I purchased a kit for a GN and DOH!.... had to send it back to Caspers for an exchange...
sure was thanks to the Electrician we all know......The wires on the car are ass backward....all better now ..........
