jretrodude
- Dec 30, 2002
What do I check or replace on this fan issue that I'm having? New temperature switch (On drivers side area) New caspers pigtails for the high and low relays all color coated and sodered professionally. Checked the high and low ac switches? And the main power switch for the radiator fan itself? Stays on the high speed at all times only shuts off when the high relay is unplugged? It's like it's getting power all the time? Also new high and low relays as well? Would could be causing it to run all the time like that? And what do I need to do to solve the issue? Also is it okay for the radiator fan to run all the time or not? Thanks.
