pull the relays off and jumper the to heavy gauged wire to make sure you have power, If you do then you need to make sure that either the signal wire ( green/yel) is giving you a ground once the car is up to temp and should be triggering the fan (165 for most cars) and also check the brown wire to make sure it has 12v all the time. If it does not, go tot he fuse panel and look at the very top at the two 5amp fuses, one of them should need replacing.
Good luck
