Need some help with my Hybrid project.
I need to decide what to do with the radiator and intercooler setup. The picture below is what I have to deal with. As you can see I have a lot of depth in the front shroud to work with but not a lot of width. The dx between the front fenders is approx 26”.
I met with a radiator guy the other day and he suggested using an aluminum g-body radiator (core dimensions are 20.75X17x1.25) and a separate oil cooler. I can’t go any bigger than this, I don’t have the room.
My options are:
Put the IC in the stock location, if I do this, It will come very close to hitting the front axle. I will need to move it forward a little for clearance. As you can see in the picture, there is a frame cross member that I will have to cut in to and it will block some air from getting to the IC.
The other option is to put it in front of the radiator, run the piping up and over the radiator and come into the shroud where it angles down. I may even be able to use the stock IC for this. I have 2 concern with this option and would like some input. First, since I am limited to a smaller size radiator, I am concerned that there will be too much heat going through that area and it may not cool the engine well enough. I will have AC. Also, since the IC will have to mount to the shroud, it will be fixed and as the engine torques I am concerned the flexing of the plumbing will cause a problem.
Any input you guys can give would be much appreciated.
Thanks,
Matt
My options are:
Thanks,
Matt
