Random parts - biggie adapter, egr cover, boost gauge, cooler
thefairbanks
I have a couple of random parts for sale that were kicking around the garage. All brand new.
Autometer Sport Comp Boost/Vac gauge - SOLD
2 1/16 size. 30psi/30hg. Mounting bolts on back were cut to fit into Autometer gauge cup. Gauge was never actually ran.
$40 plus the ride
RJC Racing biggie oil filter adapter
This will allow you to use a large capacity oil filter in place of the stock oil filter in the stock location . This increases idle oil pressure, has over 3 times the amount of filter media area and will help keep oil from continually bypassing the filter through the factory bypass.
$20 plus the ride
Champion EGR block off plate - SOLD
Comes with thick EGR plate & new Bolt. When used in conjunction with a gasket it will allow you to hold back EGR gasses on intakes that have not been filled.
$10 plus the ride
Hayden 1040 Swirl cool heavy duty oil cooler
Swirl-Cool heavy duty oil coolers are a round tube cross flow design for maximum flow and minimal pressure drop. Come with cooler, mounting hardware, sandwich plate and adapters, and cooler line.
$75 plus the ride
Located in Canada, so keep that in mind with shipping.
I'll take the block off plate. I'll PM.
Sent from my SM-N910P using Tapatalk
